Three white wires
Ok bike has no spark so took it apart, the 3 white wires that go from stator to the regulator rectifier are burnt out as are plugs that attach to the plug from the stator wiring ,  shall I just replace these wires or is this a sign of a dodgy stator
  • Replies 42
  • Views 14.4k
  • I have news, and it's good, I drained the carb float bowl and gave it a few light ish taps and and refilled and then started and it worked then didn't,  after a lot of looking around I found one wire
  • Thank F**k for that
  • neversaydie
    neversaydie
    Ive always found these two links to be useful sources of info for fault finding. They are not copyright, they are freely available http://www.electrosport.com/technical-resources/library/diagnosi
Also what amp / size wire do I need I'm in a hardware shop and didn't realise there were so many, it looks the same as a 17amp wire
you need automotive wire and first a bit of homework to work out the amperage.
first you need the output of the bike's alternator and apply the formulae (which I'm sure your capable of googling)
Ok I've tried testing the stator with a multimeter from the wires at the plug and can't seem to get any reason at all putting blacl probe on  ground wire and touching other 3 white wired and thr other wires , nothing at all.
Also I tested the 3 white wired coming out of the RR, on positive and negative, and of 6 test on 3 wires most were about 603 but 2 were about 592 ish, is this close enough or is this an indication of a knackered RR also
Thanks in advance,  I'm new to taking bikes apart and fault finding,
Cheers for those links ,  though I'm leaning more towards stator issues as the main issue was no spark so the white wires melting between RR and thr stator shouldn't have caused that presumably, can't check some things as  cant start the engine so have no idea how to test stator output, also instead of replacing wires and plug can't I just attach female spade terminals to rhe end of stator white wires and plug staright into RR male spades
If my failing memory hasnt completely let me down, your stator should have three white cables leading from it to a plug connector. It should also have two further cbales kleading to a seperate plug connecotr, most likely these may be red and green. If the stator is still in the bike, do the following.
Unplug both the white and the red/green plugs from their mating connectors
Set the meter at the sign that looks like a horseshoe
Measure between white 1 to white 2
Measure between white 1 to white 3
Measure between white 2 to white 3
Stick the black lead onto a good clean earthing point on the bike, and measure between white 1 to earth, white 2 to earth, white 3 to earth
Measure between the red and the green cables
Post the figures up to see
Might be an advantage to post up some piccys too
Awesome I will check those ans upload some pics at first available opportunity ,  also do I need the battery connected to conduct these tests as it's currently sat on my side charging?
Nope
You also need to do Step 4 on the Electrex fault finding chart, to try to isolate a possible RR fault
3 hours ago, neversaydie said:
Nope
Already done this, posted results a bit further up (12:45 on Tuesday), though if specs are the same as the article then my RR is well and truly gone .
If youve carried out the test correctly, then the RR may be good
Check stator as described now
IMG-20161115-WA0004
Spade terminals to the RR and the plug that attaches to the wires from stator plug under seat
20161119_07383820161119_073829
IMG-20161115-WA0003
The wire group with yellow tape at end is from the pickup coil and other component  attached to stator and has 2 blue wires and a green wire but go into the red/white and green/white to tci
OK checked stator
3 white wires tested at 200 ohms
A to B 0.6
A to C 0.6
B to C 0.6
All 3 wires to earth didn't register a reading at all, all 3 wires stayed at 1 , ( used engine fins as a ground)
Checked the red/white to green/white and it jumped to about 194 then back to 1 on the multimeter
Also noticed the red/white and green/white are only wires going into one plug to tci, took a pic
And orange, red ,white and black from other plug
20161120_092627
stator looks good. those shitty car connectors are realy crap, guess what? they are for cars not motor bikes.
I suspect water got in and eroded the wiring creating a resistance, so they heat up.
use 3.5mm japanese motorcycle connectors, ebay has them withthe correct shields. you'll also need a different crimper to the car one.
Well I was gonna hardwire the 3 white from stator to spade terminals attached to RR, also is the pickup coil ok as didn't get a continuous reading just jumped and went back to 1 tho maybe due to not much contact.
And still don't understand how that would cause no spark
no idea what the ohms figure to the pickup is there's a few different ones out there. You need to check the manual.
I had no spark issues few years ago and it was down to a wire, only found by eliminating it by going through back to basics. very fustrating and took a few months to suss. It even passed the OHMS test
Ok so I plugged and plumbed everything back together, and now I have what appears to be a nice blue spark in both plugs, which I'd great but when cranking it won't fire up just turns and makes a fut fut noise still, which I assume is pump putting fuel into cylinder.
Is this because I need to wait a few seconds for fuel to reach as I disconnected the fuel tank and probably drained a bit of fuel from the line, or any other magic things u should have done
