picking up a TDM850 Mk2 saturday
Looks great Drew I’d be concerned about curing in an oven though, although I suppose you do have access to larg ovens so is just warm oven for how long?
  • Replies 66
  • Views 18.3k
  • Just got back from Hull, bloody windy on the motorway and it was down to 40 mph on the higher levels. got home no problem though and the bike sounds aamzing, very comfy to ride and has good road
  • Weeks off are good for tinkering mate   Sent from my E6553 using Tapatalk
  • just restored a wing rack and fitted it today. all stainless fittings and painted silver to match the bike's frame
did it at 200'c for 10 mins starting from cold and let it cool slowly.
Its what the powder coaters do so i'm in safe territory
  • 3 weeks later...
well I've finally got the 17" wheel fitted to the TDM.
I had to have another spacer made as the original one was 2mm too small and would have put a side load on the bearing. I also had to purchase a C3 bearing as that was the only size there was that would fit the 17mm axle and the wheel.
Last thing I had to do was put a small washer twixt speedo mech and bearing as the disk alignment was out (talking 1 mm here, and made a big diference)
Got the R5 fitted and took the girl out for a ride, wow much better with handling and feels so different to the 18".
had to lower the front guard too so use 45mm x m6 stainless screws and about 25mm tubing to lower.
Lovely stuff! Better tyre choice as well
The difference when i fitted the mags to my TDR were night and day. Might nick your fitting of the front guard as mine is still too high. Got a pic?
I'm still holding out for an RG front guard.
this is  what I did for now. might buy a bar of Alloy and shape a fork breace
eJ1vwfQ.jpg?1
  • 2 months later...
bit of an update;
fitted the refurbed wheels with a larger tyre and also a new rear disk.
Also fitted the refurbed front disk using original hub. I think I mentioned the saga of the fuel dump into the engine, well I've rebuilt the carbs (even having to helicoil one top carb thread).
new inlet manifolds as the old ones were cracking, new throttle cable as I have to cut the old one off. The new throttle cable was a bugger to fit at the carb end as there are so many tubes attached to the carb.
reset the TPS as it was out
I balanced the carbs after replacing the oil filter and new oil. the bike runs a dream now, even better than before, the clutch cable was very slack but after tightening up seemed no issues and in fact changed a lot better than before. the enfoced fuel in the oil must have flushed the crud out of the engine.
no knocking noises and jobs a good 'un
