Sam001 Posted September 23, 2016 Share Posted September 23, 2016 Hi folks, just introduced myself in the new members section. I have a knackered DT125LC 1982. I have the relevant Haynes manual and have stripped the bike and given everything a good clean. I have sourced a number of the parts required (am planning on using wemoto for many parts as they seem to stock some reasonably priced stuff). its needing the usual (gasket sets) and a new piston (1mm oversized) etc etc. However, having taken the subframe off, I need to replace the pivot bolt, the two bushes (the sleeves seem fine) and the dust seals that sit in the inside of the frame. I have tried sourcing them from several suppliers (wemoto, allballs, yambits, ebay) but cant seem to find anything. I can find upto 1982 and after 1987 but nothing for the 82 - 87 bikes! So, has anyone any suggestions..... have I missed something. A member had raised something similar (in 2013 on this site) and a DTMX was suggested as a possibility (having to cut them to size). Is this the only approach and if so, is it as simple as cutting to size and fitting. Im assuming no machining is required..... Anyway, apols if I am missing the obvious - I have spent quite some time searching but whilst I have some basic knowledge and skills, I lack the experience to consider other bikes as possible donors....... Thanks..... Sam Link to comment Share on other sites More sharing options...
finnerz89 Posted September 23, 2016 Share Posted September 23, 2016 Have you tried fowlers parts? Sent from my E6553 using Tapatalk Link to comment Share on other sites More sharing options...
Sam001 Posted September 23, 2016 Author Share Posted September 23, 2016 6 hours ago, finnerz89 said: Have you tried fowlers parts? Sent from my E6553 using Tapatalk Just have but no luck. Thanks anyway, may be a source for other parts...... Link to comment Share on other sites More sharing options...
finnerz89 Posted September 23, 2016 Share Posted September 23, 2016 They have a listing for an 86 bike... Sent from my E6553 using Tapatalk Link to comment Share on other sites More sharing options...
Sam001 Posted September 23, 2016 Author Share Posted September 23, 2016 Yep, had a look, and unless Im missing it, they only have one part for subframe..... sadly lacking in that area..... I found some that are certainly for the RD (so may well be exactly the same) on ebay but are coming from Singapore and are about £35. They quote its good for the DT but have an image of the RD subframe...... I may take a gamble unless someone else has a suggestion and just assume they are interchangeable - I lack the experience to know which parts are interchangeable. But thanks finnerz Link to comment Share on other sites More sharing options...
jebb Posted September 23, 2016 Share Posted September 23, 2016 Hi, Just a thought, have you tried cmsnl.com? I used them a few times for my dt. Good luck Link to comment Share on other sites More sharing options...
Sam001 Posted September 23, 2016 Author Share Posted September 23, 2016 12 minutes ago, Sam001 said: Yep, had a look, and unless Im missing it, they only have one part for subframe..... sadly lacking in that area..... I found some that are certainly for the RD (so may well be exactly the same) on ebay but are coming from Singapore and are about £35. They quote its good for the DT but have an image of the RD subframe...... I may take a gamble unless someone else has a suggestion and just assume they are interchangeable - I lack the experience to know which parts are interchangeable. But thanks finnerz well, just found stuff for a 1986 bike on the fowlers site.... so I will give them a call..... I have the sleeves so if they are the same size as the ones on their website, the bushes should fit...... thanks for your thoughts...... 3 minutes ago, jebb said: Hi, Just a thought, have you tried cmsnl.com? I used them a few times for my dt. Good luck I had thanks..... have used in the past for my CRM250..... but thanks anyway..... Link to comment Share on other sites More sharing options...
jimmy Posted September 23, 2016 Share Posted September 23, 2016 Failing that, do you know any engineers/turners that can make one up for you Link to comment Share on other sites More sharing options...
Sam001 Posted September 24, 2016 Author Share Posted September 24, 2016 I believe the bushes are made from nylon or something, so not sure they can be machined ? Happy to be corrected...... Link to comment Share on other sites More sharing options...
finnerz89 Posted September 24, 2016 Share Posted September 24, 2016 Nylons easy to machine! Sent from my E6553 using Tapatalk Link to comment Share on other sites More sharing options...
Alan.Tdm Posted October 28, 2016 Share Posted October 28, 2016 Did you have any joy with this. The Synthetic bushes are available so to the grease seals. Maybe the bolt can be straightened ? Link to comment Share on other sites More sharing options...
volrod544 Posted November 4, 2016 Share Posted November 4, 2016 the bushes are part number 90386-18028,the outer seals with the steel cases are 401-22128-01 and the inner oil seals are 93109-18020 Link to comment Share on other sites More sharing options...
