This post is 3021 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Any advice on weather this normal? I have bought 2 sets of shocks now and none of the metal bushings fit..
I also can't tell if that is one stuck on the bolt...
Many thanks for any help or advice in the matter.
Well the top vid looks like the shock spacer is too small and the 2nd vid looks like you have a spacer already on the mounting bolt, I think the problem is that you haven't taken the old shock spacer off, might be completely wrong but it's my best guess anyway from what I can see!
  • Like 2
thanks for your reply.. the bike did have original shocks but were damaged, and yes that is what i was thinking but its definitely on there. and didnt want to mash it to no avail then put rubber to it...
will try over the weekend many thanks for your advice.
The bottom mounting is supposed to be like that . It is a shouldered stud. Try and pick up a manual, it shows it in there
When I bought new shocks they actually came with two sets of bushings... Could you not take the bushings out of your old shocks? Or are they trashed?
Thanks for your reply.. I did get a pair of bushings with both pairs but none fit over the bolt on swing arm. Which is why I agreed that there must be one left on there, I'll have another look later in the week
I'm with Jimmy though... I think that stud is supposed to be that way. :eusa_think:
On some of the bikes I've had there has been a stud with a top hat sort of thing (bush and large washer) that went over it, if you look close it does look like the thread goes under the bush? But more than willing to say I'm wrong!
