Just an update guys. I finally managed to get it off. After buying one of those multi size sockets with all the pins in that adjusts to the size of the nut and failing miserably I bought some of those sockets specifically for getting rounded bolts off. Inside they are spiralled similar to the rifling of a gun barrel.I got one that was just too small to fit on and then gently tapped it on with a hammer and it come straight off. Thanks for all the help, I got there in the end.
  • Replies 42
  • Views 8.7k
  • I've come on leaps and bounds. I do all of my own basic maintenance now. At one point I couldn't even change my brake pads. A lot of it was having the confidence and of course advice from you guys has
  • You take the side case off for the filter( i think) You can drain it then. Need to be carefull and may be messy without somebody to keep the bike leaned over. But it will drain the oil.
  • Maybe with fresh oil
Posted Images
I've come on leaps and bounds. I do all of my own basic maintenance now. At one point I couldn't even change my brake pads. A lot of it was having the confidence and of course advice from you guys has helped me a lot. It might take me a bit longer than a mechanic but it gives me something to do. I think my next task is going to be to fit some braided braided brake hoses now the weather is perking up.
