April 8, 20169 yr the rear peg keeps on falling down when I'm out, it's annoying. how can I fix it, I'm too tight to buy another , plus these are originals but are well worn. best ideas welcome ,
April 8, 20169 yr Moderator try locking thread glue and maybe a washer may tighten up the fixing. did you go to pasty and pea night last night?
April 8, 20169 yr Author it's not the nut that is coming loose, it's the retainer allowing the peddle to fall down . it's worn out, I need a new one realey but if I can get away with a fix , then that's the way forward didn't know the pasty pea was back on andy, when the bikes back on the road I will have a ride there. I should be going to the sprint run at Houghton tower too, I don't know what date that's on though .
April 8, 20169 yr Author did any other yams use the same pegs as the rd. maybe I could look on flea bay with a wider option.
April 8, 20169 yr Author cheers paul ,but I just found these , compare the price. http://www.motorcycleproducts.co.uk/footrests-yamaha-rd350-lc-rear-p-68907.html?gclid=CM2GgJXd_8sCFYMK0wodnssBBQ
April 8, 20169 yr Author well I will piss about with these a bit more then make my mind up which to buy.
April 8, 20169 yr Moderator I'll have a look in my spares bin tomorrow, might have some shitty ones (new) you can have any use?
April 9, 20169 yr Moderator 8 hours ago, up.yours said: ta andy. but I want them looking original. no probelm, open your wallet and get the yambit ones have you tried rdlc crazy? norbo runs it http://homepage.ntlworld.com/ultimatelccrazy/html/for%20sale%20page%202.%202%20350lc%20.htm
April 15, 20169 yr Author On 08/04/2016 at 8:53 PM, Airhead said: God they look shit kev but each to his own I suppose they are paul. , tacky flimsy poor crappy shit infact.
