Old exhaust polish / rust
Hi everyone, silly question time,  I have been trying to remove rust and  polish  The old stock exhaust on my Yamaha dragster 1100.
 This is a test as I have new exhaust on the bike, I have noticed that the rear of the old exhaust is not mirror finish chrome not sure if it was like that normally or excessive polishing has dulled it.
tried to take a photo as below.
or maybe not as cannot upload photos for some reason.
not a bad result looks much better
It may be that the original finish has dulled due to the heating/cooling cycles of the exhaust system. Surface rust removal usually requires an abrasive of some kind. Depending on how bad it is, but I use a dremmel type rotary hand held and a small wire wheel. Polish up with the polish of your choice
Thanks will give it a try
Theres aguy  om u-tune says the fine steel wool  0000 Grade, and polish .  I "l try  and post video ,
Imagine what it's doing to your gut.
I have heard tin foil and cola works very well
