1983 Yamaha TR1
Acceleration, braking, cranked over in your favorite bends  and roundabouts. You will move around a lot.
I just think its something that deserves as much thought as you have put in the rest of the bike.
  • Replies 88
  • Views 27.4k
  • neversaydie
    neversaydie
    Workshop? Its an operating theatre
  • Quickly chucked the thing back together (there will be a lot if stripping down and building back up) to have a look at the effect of the frame cut. I'm more than happy
  • Another bit of mesh to tie things up a little (probably have a small bit on the rear hugger if and when I acquire one). Mesh and mudguard will both be black &#13
Posted Images
Oh it has been thought through. It will be more obvious once the finished shape of the foam is done
Bare in mind the bike currently sits with no forks in it. The sitting position is flat once the bike stands on two wheels :)
  • 3 weeks later...
Incredibly slow work at the minute. Work is crazy busy and other commitments are taking up all of my time but I have had a little present.
Chrome seems quite appropriate for the bike (my tassles are on order) rofl
C'mon Jack, you've kept us hanging around for 10 days now....we need updates
:D I'm self employed and work has been crazy so done very very little for some time now. On top of that, race season started for us last weekend so preparation for that has taken up quite some time. I promise to get back to this asap
I do now have the single carb conversion kit arrive so may start tinkering very soon
  • 1 month later...
Hi Jack
i have in my garage a stock tr1 that I'm going to turn into something very similar to yours, so I'm following your build closely!
im going tu use an r1 front end and the sv650 rear wheel and brake caliper, did you use the 99-02 or the later ones?
is there much difference between the two? Before I go out and buy the wrong bits!
thanks T
Hardly any difference between the two mate. Just bearing and therefore spindle size.
Why are you going to the Yamaha front  and Suzuki rear ? The reason I went for the GSXR front ws to match the wheel to the SV. You will have different shape wheels the way you are descrbing
Hi jack
already bought the front end, most builds I've seen pics of have different wheels. At least the r1/XS have 3 spokes and once they're painted and some nice waves discs only the very sharpest of eyes will notice (I hope) !!!
Just a quick one to say I'm still here but struggling to find any time at all to work on this. I have had time to dry fit the 2 into 1 manifold and 40mm flatslide carb. Looks so much better than the standard twin carbs  [thumbsup]
7 hours ago, drewpy said:
I'm in touch with a German guy on youtube who is supercharging a TR1.
I'll update when I get his blog details
I think that would be Nanno. It's a great build !
  • 3 weeks later...
The sparker TCIP4 inductive programmable ignition along with  has turned up from The Czech Republic
Nearly ready to set about making the new loom up
  • 3 months later...
  • 2 months later...
Sorry for the late reply. I have been crazy busy at work and not touched this (other than stripping it down to bare bones for the umpteenth time. Will be picking it up and running with it again very soon
  • 2 months later...
It's been way too long since I've done anything to this. The bikes has been in bits scattered between my work and home garage. I've got the bit between my teeth again so have got the thing back together again
I've sourced a nice rear brake disc for the SV rear wheel
Ive even tidied my workshop up to make it a bit more inviting
