Posted October 13, 201510 yr Both my ols YX600 Radian and my present XV750 had/have these fitted. Im a fan of em. Id like to mod the FZ6 fro them. I originally thought that the timer was inbuilt into the relay, and I could just swap out the realy, but now I dont think thats the case, I reckon they pick up the signal from the speedo/odo, based on distance travelled after the relay is activated. A timer would simply switch off if you were stopped at the lights. Has anyone modded their bikes to fit self cancelling turn signals?
October 13, 201510 yr Moderator you are right aboput the speedo , you would need speedo and sensor , the correct flasher unit , and the self cancelling realy that is hidden under the frame somewhere , basically it will be a PITA to do i reckon
October 14, 201510 yr Author you are right aboput the speedo , you would need speedo and sensor , the correct flasher unit , and the self cancelling realy that is hidden under the frame somewhere , basically it will be a PITA to do i reckon Agreed. Backheeled into the long grass
