Self cancelling indicators
Both my ols YX600 Radian and my present XV750 had/have these fitted. Im a fan of em. Id like to mod the FZ6 fro them. I originally thought that the timer was inbuilt into the relay, and I could just swap out the realy, but now I dont think thats the case, I reckon they pick up the signal from the speedo/odo, based on distance travelled after the relay is activated. A timer would simply switch off if you were stopped at the lights.
Has anyone modded their bikes to fit self cancelling turn signals?
you are right aboput the speedo , you would need speedo and sensor , the correct flasher unit , and the self cancelling realy that is hidden under the frame somewhere , basically it will be a PITA to  do i reckon
Agreed. Backheeled into the long grass :)
