Posted September 13, 201510 yr Hey everyone. Im having issues with my V50 atm where my exhaust is full of oil. The previous owners use to run car engine oil through the pre mix system instead of normal 2 stroke oil (it says motor oil on the cap and they got confused) so im wondering what methods are best to clear it out so the bike can breath. Cheers
September 14, 201510 yr I usually soak it with diesel fuel then blow it away with pressurized air, but if its clog best way is to weld it open to remove the carbon build up.
September 14, 201510 yr Moderator Oven cleaner. Nastiest you can find. Plug one end then pour in.Plug the other end and turn it over several times then leave overnight.
September 14, 201510 yr Fill with tilt cleaner leave for 30 mins and steam clean out don't forget your ppe, tilt cleaner is nasty stuff but dissolves oil like magic
September 15, 201510 yr Those chemical will surely work, but quite expensive diesel fuel or thinner are more affordable and would offer the same effect.
September 15, 201510 yr Moderator Thinners wont touch the carbon. Neither will the derv without scraping, not to mention it will smoke like the qe2 till it burns off.Jmc oven cleaner. 2quid or so.
September 15, 201510 yr Moderator can't you do what we used to do. build a bonfire and chuck it on that. all carbon gets burned off and just tap out the bits
September 15, 201510 yr Don't do the chrome any good though, the real but nasty answer is caustic that's what we used in the 70 s
September 16, 201510 yr Author Turns out that the baffles which are removable were blocked which is causing the majority of the issues.
September 16, 201510 yr pre mixing is the answer, I have never had to clean my baffles in the seven years I have had the bike, and nether did my mate in the twelve years he owned it.although some people like there bikes smoking and oiling up all the time so the choice is yours.
September 17, 201510 yr Moderator You rag the bollocks out of that. At 3am on a campsite sometimes.Bikes used properly dont coke up cos the engine gets prpoer hot and burns it off.Its chugging along in rush hour traffic day after day that chokes em.
September 17, 201510 yr Author I personally prefer to Premix but for the meantime for this bike il be using the self oiler and see how it goes...
September 17, 201510 yr bootz1 take a leaf out of my book and rag the bollocks off it till it clears up , but don't get caught . speaking of which , I got caught not wearing my seatbelt the other day and issued with a £30 fine . my excuse of riding a bike and not being used to putting it on didn't wash with them.
September 17, 201510 yr Author Well ive taken out the blocked baffles (baffles are fail anyway) and given the pipe a clean through with some degreaser cause it wasnt that bad once the baffles were gone. Now just gotta spiff up the bike, and put it all back together and see how she goes!
September 21, 201510 yr Author Went for a test ride this afternoon- so much better! actually breathes and pulls down low instead of going ah nah no thanks u can putter about everywhere
September 21, 201510 yr Right then ! Now you have done that, keep riding it flatout and you shouldn't have anymore trouble with it.
