August 23, 201510 yr Sure didn't know what I let my self in for when I picked up this half started trike conversion.. Bike had been sat in old shed for nine years. No exhaust pipes ,seat and many other small electical bits like fuse box ,flasher unit .etc.. ..clutch appears to be seized ,other than those little problems it seems to be fine.!!!,,, so question ,is the clutch easy to get to?? ....
August 24, 201510 yr Moderator Sure didn't know what I let my self in for when I picked up this half started trike conversion.. Bike had been sat in old shed for nine years. No exhaust pipes ,seat and many other small electical bits like fuse box ,flasher unit .etc.. ..clutch appears to be seized ,other than those little problems it seems to be fine.!!!,,, so question ,is the clutch easy to get to?? ....depends if the trike frame was built around the right engine case, usually very easy to get to
