Posted July 13, 201510 yr I have a 1979 Yamaha xs1100sf. bout new led blinkers. they will not blink. tried a up to date flasher, and all they do is come on with the blinker switch. the stock ones worked fine, just bulky and big. any suggestions.
July 13, 201510 yr pictures of the bike and i'll tell you what you're missing...... hahahaha yeah, i'm a prick. What i think you're missing is 'led indicator resistor' also known as a 'flasher relay' Have a google and see what you think.
July 23, 201510 yr When you swap to LED sometimes the flasher units dont register it so the indicator will either stay illuminated or not work at all. This is because of how the lights are lit via the current. Most after market LED's will need a new flasher unit that drops the voltage to the correct spec. Did you check the working values of the lights to see if they matched your harness/loom before buying them?Â
July 23, 201510 yr 'Blinkers' are those things you put on the side of a horse's face to stop rowdy crowds and Foamy Photos from scaring them.An LED Relay for 'Indicators' are what ya need!!
July 25, 201510 yr Try one of these things, http://www.ebay.co.uk/itm/311379442933?_trksid=p11400.c100367.m3766&_trkparms=aid%3D333008%26algo%3DRIC.MBE%26ao%3D1%26asc%3D20150120121033%26meid%3D49dfde37ec4448e48f538813eba351ad%26pid%3D100367%26rk%3D2%26rkt%3D8%26mehot%3Dag%26sd%3D301692305290
