June 14, 201510 yr Hi guys, does anyone have any tips on how to clean up the outside of carbs? Mine are not too bad, but since I've had to remove them to change a clutch cable I thought I'd try to clean them up. Cheers Garry
June 14, 201510 yr Moderator Elbow grease and things like petrol, thinners and a toothbrush. Try the pound shops, one near me called rock bottom does big cans of carb cleaner for £2.99. Works on the outside as well as the inside. For god sake dont try to polish them, just let them age with dignity (aluminium will bloom just with age) unless you want to spend your life with a polishing mop.
June 14, 201510 yr Being a cheap bastard I do like the pound shop, got engine degreased using their oven cleaner, much cheaper than the proper stuff.
June 14, 201510 yr Author Bloody hell I think my other half has got some of that in the cupboard I'll go and nick that for nothing!!
June 14, 201510 yr Moderator Boil them in a lemon juice (jif) and water mix - use an old saucepan. Don't leave them too long and wash in plenty of cold water as the lemon will eventually eat the alloy. Finish off with some WD40 and a cloth.
June 14, 201510 yr Bloody hell I think my other half has got some of that in the cupboard I'll go and nick that for nothing!! Ha Ha Ha !!! Not just me then?
June 14, 201510 yr Moderator Nah, lemon juice, ie citric acid wont harm aluminium. Its non ferrous so its caustic that can really damage it. ie oven cleaner (although by the by that stuff is really weak), make sure you wear ppe while your working it. Vinegar works too. Just be careful with the oven cleaner. Although that gunk you use with the bag really works on decoking spannies.
