Hi everyone my name is Steve , I've just got back into bikes after a long time away. I had Yamaha,s when I was younger and always liked the style and performance
Hi and welcome.
I have moved your post out of the help section so more people will see it.
Welcome aboard!
Thanks for the welcome
I've just bought a 1984 it 200 and I'm getting ready for mot , it's a California import so would be thankful for any advice on what's required ie brake lights hi beam ect as it doesn't have any of these thanks
Is it on a NOVA?
Lights would depend on if you are going for a full MOT or a daylight one.
Daylight MOT Regs.
A daylight MOT would require a motorbike to have a horn and a rear registration plate.
The testing guidelines state that motorbikes can be exempt from having lamps tested if they meet the following criteria:-
machines which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are:-
  • only used in daylight hours
  • not used in times of serious reduced visibility
The following items/lamps are not required to be tested in order for a MOT to pass a daylight MOT test as long as they meet the criteria above.
  • Front and Rear position lamps
  • Headlamps
  • Stop Lamps
  • Rear Reflectors
  • Direction Indicators
VOSA can only advise on MOT standards queries. For information on the legal requirements you will need to address your enquiry to the Department for Transport, as they deal with the Construction and Use Regulations and Road Law.
The Department for Transport can be telephoned on 0300 330 3000, or you can visit their website at www.dft.gov.uk for further contact information.
Thanks to all , it is on a nova so all duty and taxes paid , I have certificate for this . I was told I have to have insurance and mot before they will issue an age related plate . I would prefer a full mot so I need electrics sorted . I want to put an ignition switch on as well, is the electrical work something I could do ?
Hi steve " :welcome: you"l need a dating cert for proof of age, OR, the original Title [ usa log book] , insure it on the frame number,
