Tzr 125 when pulling away bike wants to die
Howzit going guys. I recently bought myself an yamaha tzr 125 2RK and whenever I start it it idles fine and then all of the sudden the revs drop and the bike just cuts out. Also when I want to pull away with the bike the bike sounds like it wants to cut out and then jerks a little or it will just cut out, but yet starts perfectly after the cut out. Another thing when I switch the bike off and close the tap the float bowl petrol runs out. Please help on this one. Thanx [emoji20]
Its staring you in the face, fuel flow, and float level/ valve :yeah:
Fuel flow meaning the petrol going through the carburetor and where do you set the float level/valve? There next to your carburetor where the two screws are?
These are not off of your bike but tell you where the float is and the hole that takes the float needle and where the tang on the float is, all bike carbs are enough the same that it should give you some idea of what to adjust.
Shot alot slice. Yeah will have a look in the morning. Felt on the side of the float bowl the inside part by the motor it's leaking there. Quite strange but will for sure have a look.
