April 17, 201510 yr Got a yamaha aerox 2010 after 3 mile the light comes on and it gets sluggish any help guys please
April 17, 201510 yr Hi Manny, it's normal to do an INTRO before you ask a "how do I fix my bike" question, so if you would do that it would be great thanks (new members section), now your problem, I think you might need a bit more info before anyone can offer advice on what the problem might be, if any, you see saying "it gets sluggish" is not what most would call helpful, not your fault mind it's just that is not much to go on. So if you would be kind enough to say WHY you think it's a problem and what it did before you had this fault! then that might help with an idea or two as to what might be wrong. We're just a bunch of people who like riding and we help out if we can but like most of these things without enough info we can't help till you tell us more mate. Anyway Welcome to the YOC.
April 17, 201510 yr Hey jossun ok new to this not sure how you post in rooms so if u could help me no problem i will introduce myself thanks [emoji106] Sent from my iPhone using Tapatalk
April 17, 201510 yr Sorry its manny it signed me in through google jossun [emoji106] Sent from my iPhone using Tapatalk
April 17, 201510 yr Hey dirty the thermostat light comes on only just started riding it ive had the front off and the coolants flowing down but should it be so pink i have not had anything else off though Sent from my iPhone using Tapatalk
April 17, 201510 yr Hi, if you don't know what your doing ,take it to a friend who does, or youl knacker it big time,, its a 2 stroke aint it,? check oil tank also,
April 18, 201510 yr Moderator I dont know much about them but If it is the temp light then the are 3 water things to check, water pump, termostat and air lock. Timing and lack of 2 stroke oil can also cause overheating. Got to agree with Blackhat, you will kill a 2 stroke if it gets too hot.
April 18, 201510 yr Yeh i know guys i ride kx 250s but everything else seems ok so just a bit miffed should i check the thermostat then see if its stuck ?? Sent from my iPhone using Tapatalk
