Posted March 3, 201510 yr Looking at potentially selling my WR400, However ive no idea on a price to ask. Can anyone give me an idea on what you think its worth? Freshly rebuilt top end (new valves/stem seals from Wiseco USA) - 560~ miles on this, due valve check and oil/filter change (will be done before sale) lightly ported and polished exhaust ports on cylinder head, lapped valve seats. FMF Titanium exhaust - from header back Gold Morad Supermoto wheels with talon hubs (same as drz) Trailtech Vapor dash - measures water temp,rpm's & speed - plumbed into bikes electric supply Samco blue rad hosing West coast seat cover (imported from USA) UFO Plastic Supermoto front and rear fenders DRC Edge 2 tail light New Putoline air filter New fuel tap kit Smaller number plate (8x6) - mot plate included new chain and sprockets JT + Renthal new swing arm and chain sliders new head bearings new waterpump shaft and seal kit - Yamaha RFX fork bleed screws RFX Fuel mixture screw new Goldfren front and rear brake pads New Putoline DOT4 brake fluid New Head Gasket Renthal grips - soft compound all new clutch/brake cables new Swingarm bearing kit new fork seals - used Putoline fork oil replacement brake lever (due to MOT advisorie) Iridium spark plug battery opoerated horn Spares: HotCams complete shim kit (imported from USA) Red engine stand (made by a friend) Motorcross bike stand (modified to suit offroad wheel bike height) frame covers brake covers spare exhaust header old exhaust Offroad wheels - new bearings and sprocket - rear wheel needs a new disk Spare tyres for offroad wheels (around 4) Trailtech Vapor coil wire + power wire 2 x bottom end crank cases (so spare clutch/water pump etc) 1 x box of top end bits (from the original owner) cam cover/various nuts/bolts Documentation - I've got a plastic wallet full + v5 in my name etc. MOT Passed with 2 advisories: 1. Exhaust Noisy (was before the titanium sealed exhaust was on) 2. Rear Brake lever short(put new full length lever on now) Again just to reiterate, All the parts on the bike have only 500 odd miles usage, the bike feels amazing, feels very light in the corners, wheelies 1'st, 2nd off throttle etc. Bike will be having valve clearances checked, oil changed and new filter before sale. http://youtu.be/pmqy4Oq1AaY?list=UUX4NqjbQte8apqb85VvNvfw Cheers Ross
March 3, 201510 yr Only you can put a price on it matey. If you put it on fleabay with a reserve of a figure you're happy with, it will find its level there.
March 3, 201510 yr Author Only you can put a price on it matey. If you put it on fleabay with a reserve of a figure you're happy with, it will find its level there. Suppose, i had thought around the 1600-1700 mark. but i cant find an example of such a fixed wr400 being sold on ebay with all the spares etc.
March 3, 201510 yr It's only worth what someone will pay for it, no matter how many hours or spares you throw in. Good luck hope you get your price.
March 3, 201510 yr Maybe look at bikes in the same(as close as) condition, and put it up a frew hundred since you've got it in sich lovely shape and all those spare parts, it's definately worth more than your average second hand WR, but then again, like he said it's only worth what someone will pay for it.
March 7, 201510 yr as said above. just finding the rite buyer. iv seen them sell for 1200 and seen a few fetch 1700. just depends when somebody is looking one.
