Just imported a 1989 Yamaha TDR250. What is the red light on the bottom of the speedometer?
:Hi parsons :jossun: it be the 2 stroke oil light, it will light in neutral[ bulb check] , and then only come on when oil tank is low,
Member Cynic has experienced this :babyha:
It has an oil light on the top of the instrument cluster that does exactly that, goes off when in gear. There is another red light at the bottom of the speedometer that occasionally comes on briefly, about 2 seconds. I downloaded a shop manual but it doesn't address the issue.
Is that if you go over 55mph?
I'm not sure, rode it for about 25 miles.
I appreciate the suggestions but does anyone out there have one?
NO
In japan a red light is fitted in the spedo that comes on at 55mph (their national speed limit).
Straight swap for a uk spedo. Or if you can get your head round kph. Pull the bulb or it will drive you mad as its so bright.
I swapped the spedo on mine.
Thank you very much.
