Hello I have just had an engine rebuild what would you suggest the best way is to ride in the engine
Hello I am just asking what would you suggest the best way to ride in a rebuilt engine
First 300 miles I'd keep the revs to no more than 60% of redline and riding for no more than an hour at a time. 300 to 600 miles avoid full throttle. Change the oil and filter after 600 miles. As it's a dragstar you're probably going to want to polish it a lot :eusa_whistle:
As above really. Treat it like a new bike - do you know what the original owners manual says about running it in?
well I did the opposite, first few miles, take it fairly easy not loading the engine.
the next 20 or so I gave it some letting the engine rev to 80% of its top end and not loading the engine up. This stops the bores glazing and helps seal the piston rings.
I used mineral oil for that, then I drained and put semi synth in with a new filter. Bike ran a dream for the 6 years I owned it and no puff of smoke at all!
I clean it every day and thanks the manual online doesn't say anything about engine rebuilds only a new engine
clean round to the redline and keep her at it.....
ok maybe not :hyper: just dont go mad with the revs and it will be fine.
  • 1 month later...
hard run in every time
use mineral oil, get it warm, thrash it briefly heavy load med-high throttle, let cool by cruising for short time, repeat - drain oil after first few runs.
so many cars and motorcycles are run to their peak rpm/load on the dyno, this does most of the ring bed in, the fluids are often dumped and refilled. the take it easy is more of a thing to ensure suspension or other components aren't faulty - the 1000km service is meant to have a thorough once over for loose fasteners, faulty suspension etc anything that could have been done incorrectly at the factory that could cause catastrophic failure - this is my opinion but if you look at car factory vids and engine building stuff most of the bed in is in the first-second time the motor runs. i've known people with drag cars to bed the rings in on the strip.
