Hello everyone
I have a yamaha YA6, it does not exceed the speed of 80 km / h.
Electrical or mechanical problem or carburetion?
Hi Mario " I would think carb , but exhaust may need De-coked, or a rebore if compression low,,,
There is a new members section on here ,,pop up an intro,, :yeah:
On the issue of carburetion.
Accelerated more or less at half throttle, the bike is noted as drowned, shot choke but does not exceed 80 km / hr.
Could be the main jet or the position of the needle?
main jet standard: 190
Needle Position: 2nd. top
pilot jet: 30
The carb specs are right. They may be worn or, as Blackhat says, need a rebore, new plug/airfilter/genuine jet replacement etc.
When new the bike should have reached around 110Kph - but the bike is 45 years old!
Amazing technology when new.
Float level is currently 26.2 mm.
How is the factory specification?
Much does the float level?
The book I have to hand does not have the float height but some other specs to help:
Spark plug B-6H or M45
Plug gap 0.6 to 0.7mm
Points gap 0.3 to 0.35mm
Timing 2.5 to 2.6mm before TDC
  • 5 months later...
Hello !
How about going to the "New Members" section & doing an introduction ??
Its considered polite & also you will get more responses from some of the members.
Lots of wisdom in this Forum. Hope you find the answer to your problem.
