DT250 / DT400 engine into DT175 frame
This post is 6345 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
  • 9 months later...
can it be done, is there the pysical room, would it be stable enough after
before I go out and buy an engine :unsure:
IT CAN BE DONE. REQUIRES TIG AN OR MIG WELDER. DIE GRINDER WITH CUTTING BLADE. NEED TO CHANGE REAR WHEEL SPROCKET TO MATCH PITCH AS USED BY DT400'S.
