Just for fun..useful info for mechanics
Vacumn Gauge: An instrument used to measure the pressure exerted like sucking on a straw by human or machine displayed in non-metric ruler increments.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive chrome scooter parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing leathers or bike covers.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling rollbar mounting holes in the floor of a sports car just above the brake line that goes to the rear axle.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting those stale garage cigarettes you keep hidden in the back of the Whitworth socket drawer (What wife would think to look in _there_?) because you can never remember to buy lighter fluid for the Zippo lighter you got from the PX at Fort Campbell.
ZIPPO LIGHTER: See oxyacetylene torch.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for hiding six-month old Salems from the sort of person who would throw them away for no good reason.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against the Rolling Stones poster over the bench grinder.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Django Reinhardt".
HYDRAULIC FLOOR JACK: Used for lowering a Mustang to the ground after you have installed a set of Ford Motorsports lowered road springs, trapping the jack handle firmly under the front air dam.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor Bubba to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup on crankshaft pulleys.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and hydraulic clutch lines you may have forgotten to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from scooter battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty suspension bolts last tightened 40 years ago by someone in Abingdon, Oxfordshire, and rounds them off.
:D Couldnt agree more with your tool set twirly but you did miss out one and thats the
50p spanner from B&Q which convinces you it is a snap-on in deferent packing..
Good for ripping your knuckles off on the first atempt as the bloody thing breaks on that nut that hasnt moved for a few years and after the swearing and shouting and the wife saying "carm down you wont get any where like that" is it just me or does that wind you up even more specially when they say it with a smile on their face.
Then its onto the vice grips say no more
