Ignition an kill switch problems
Hi guys I have a 2002 dtr 125 it's a sweat little bike but I need help with the kill switch an ignition
It will start with out the key if the kill switch is on run but if you turn the kill switch of it wont
So for it to run at lest one of the kill switch or ignition had to be on the only way to turn it off is if the kill an ignition is off
Any idea on how to solve this problem it's hard to have a settle head when I can start with out a key thanks
Thanks for the reply airhead I have friends that worked in bike shops for years an he is still trying to work it out a week later
Really need to get it fixed soon it can't pass an MOT like this
Got to agree with Airhead. The killswitch is just an earth to stop the coils from sparking.
What happens when you disconnect the kill switch? Does it work or not??
Thanks dirtyDT for the reply it's a problem for me at the moment lucky I have till March where I can legally ride it but I just need the MOT passed but just trying to find a solution
Unfortunately I'm not sure the person helping just did what he did an went confused but coming back round sat to have another look so I can try on sat thanks for the advice
Do you know of this is a way to pass the MOT or do you need the kill switch to work ?
Will do if I get time tomorrow I will try unfortunately I'm 16 an never done anything like this but I can only Learn I guess will do airhead
An it looks like when the old owner put a aftermarket headlight on this is where the problem had came the wiring was a mess
Yeah thats the trouble with old people, most of em are stupid...stay young :D
Will the bike pass the mot if you remove the kill switch altogether for the test ? (Assuming the ignition works ).
my tracker passed without one
you don't need a kill switch for the mot, but if theres a switch there, then it has to work for the mot
