October 21, 201411 yr Just wondering. Is there anyway you can make the YBR go faster just to give it that little bit more power so it can go a steady 70mph all the time. I'm just wondering because I love the YBR 125 I had 2 of them because I find them a really reliable bike but would like that little bit more power any ideas.
October 21, 201411 yr Hi jon" its a 125 , so limits are about max as it is ,, save your money for the test , as bigger bike is the way to more power,, pop an intro in newbee section
November 3, 201411 yr Do you really want to do anymore than 65ish on a YBR125, I find mine really skittish at anymore than 60mph, I'm just going to put up with mine until i do my test and get something a little bigger thats more comfortable at A road speeds
November 4, 201411 yr Moderator Find a rear sprocket with one less tooth. This will give you slightly slower acceleration but a better top speed. Therefore if the standard sprocket is 45 teeth, you need to find one with 44 teeth. The opposite applies to the front sprocket.
