TDR250.co.uk
Hi all, I need some help
I want to get into the above forum but I've tried and failed over the last 3 weeks.
Is it still operating? If so.....
Can anyone put me in touch with a moderator or administrator to help me?
the Board Administrator contact button just doesn't work.
Cheers.
In the meantime does anyone know if UK TDR 250 barrels & pistons are a direct fit onto a french TDR 240 bottom end?
Or is the crank throw or something else a problem?
How can a 240 be identified by its frame and engine numbers?
Is there a significant difference in performance for the 240?
Thanks all
Same for me works fine.
240 barrels are a straight swap and if you werent told it was a 240 you wouldnt know from riding it. So long as its fully fit.
