slice Posted September 20, 2014 Posted September 20, 2014 Hi All, well I am wondering if anyone knows how to adjust a Hagon mono shock? It has the usual threaded nut jobbie on the top with a thread that goes down to about half way and that's it really but the one that the bike came with was quite complicated and this looks much simpler but I have no idea how to adjust the rebound on the thing. I suspect that you just have to wind the big nut on the top down till it meets the spring but how do I know when it's in the right place? Any advice or even a pointer towards someone who might know would be appreciated, Thanks boys and girls.
slice Posted September 20, 2014 Author Posted September 20, 2014 S'all right got onto HAGON they told me how to do it. No prob.
KevtheRev Posted September 20, 2014 Posted September 20, 2014 Hi there , adjusting the spring tension adjusts pre-load only ( i.e. to suit riders / luggage of different weights ) . Some shocks also have adjustment for damping and rebound damping , and some also have adjustment for high and low speed damping . These adjustments are usually made by turning an adjuster screw ( intervals measured by "clicks" in or out ) , which can be at different locations on the shock body . Without knowing exactly which shock you have it's impossible to be more specific . Usually Hagon shocks come with an advice / instruction sheet , failing that you should give them a ring .
KevtheRev Posted September 20, 2014 Posted September 20, 2014 Right , just saw your second post , ignore the above , lol .
