what will happen if i leave the baffles out , as it picks it's feet up better without them.
am i risking melted pistons or will it be ok apart from the extra decibels :shrug:
whats a plug chop
On my old 81 I pulled the baffels and replaced them with some alui pipe from a lawn chair and drilled as many holes as I could and didn't have to rejet. See a few guys run without baffels but I think thier bikes were slower as they wern't getting the back pressure and scavenging effect the baffels help with.
Plug chop run bike to full rpm in top gear kill ignition and at the same time pull in clutch,stop and pull spark plugs and see if the are coffey colour or white coffey is good white is bad(lean)
:yeahthat:
right , i will do it tommoz . if its still coffee coloured and pulls better like it is doing , im good to go am i.
Not if it is black coffee colour. Think digestive biscuit, I'm sure you had a few of those.
they will be staying in, it went too lean ..
lost a feckin baffle today , it's your fault john :biglaugha: that screw didn't hold,
i didn't get round to replacing it.
im going back over the moors tomorrow to see if i can see it..only did 22 miles :shakeno:
it's a bit battered but i found it..
Well done! Surprised you found your way back to the same roads again though :)
your so rude andy.
anyhow a genital tap and squashing with snip nosed plyers have got it back in shape.
finished with a squirt of bbq black.
your so rude andy.
Genital tap, you got rocks for balls then?
:biglaugha: yup , wanna touch them
