Posted July 30, 201410 yr Hi Ive recently bought a very low mileage 1989 rxs100 and have only ridden it less than 1/2 a mile but it seemed a bit sluggish. I've found the airbox has been butchered to fit a cone filter and holes drilled all over it. ( looking for a complete 1 if anyone has ) The carb however hasn't been jetted to suit as its still running a standard 120 main. The main issue I've got is I've dropped the gearbox oil and its full of fuel!. I take it the reason will be the right hand crank seal ? I've stripped this out and a new 1 is on its way. I've stripped the left hand casings off and theres no sign of fuel behind the flywheel. Can I take it this side seal is ok. I'm thinking of just replacing the right hand seal and seeing how it goes. Any thoughts would be appreciated thanks.
July 30, 201410 yr Moderator ................Any thoughts would be appreciated thanks. My thoughts are that this is a workshop question and should be in the workshop section. Topic locked.
