Posted July 9, 201411 yr What`s going on..my URL`s not copying onto the site. Is there a problem on the site?
July 9, 201411 yr Author IMG tagged URL from Photobucket..It does copy onto a word document but not onto this site.
July 9, 201411 yr Moderator So the code is: http://i1361.photobucket.com/albums/r680/mcferreira100/2014-07-08122942_zpsd2d45e11.jpg Are you clicking the arrowed icon in the picture below Then pasting just the code above into the box Then pressing OK? If the icons are greyed out click the switch to the very top left of the icon box by your picture. Otherwise use the following image tags [img]http://i1361.photobucket.com/albums/r680/mcferreira100/2014-07-08122942_zpsd2d45e11.jpg[/img] The cut and paste works for me.
July 9, 201411 yr Author :eusa_think:ok hit that top left button and it worked. Never had to do it before though.
July 9, 201411 yr Moderator not the way I did it though, I justed clicked the IMG field in photobucket, it responded as usual with 'copied'...then I pasted it in the forum, that's the way I do it.
July 9, 201411 yr Author yep that's the way ive also always done it..i never had to fiddle with any icons. Its fine..not a train smash.
July 9, 201411 yr Get the drop down box on ph/bucket of picture, select get links, another BIG box appears -click on IMG ,,, should flash Copied
July 10, 201411 yr Mc I had a similar problem with my machine, I asked ALEX what was happening and he had no idea what was going on, I switched to FIREFOX instead of IE and not had a problem since.
July 10, 201411 yr Moderator Sometimes, and I don't know why, the post input box turns to code only mode. This is fixed by a single click on the very top left icon. I recall it happened to up.yours a while ago.
