Posted June 23, 201411 yr im going to replace the seals on my caliper.been looking around,ive only seen the piston seals and piston.where can i get the calliper middle seals
June 23, 201411 yr Not sure what you mean by "middle seals" Some calipers are made of 2 halves, bolted and dowelled together, mostly they come with advise never to seperate Unless there is evidence of leakage there, I think Id be inclined to just replace the pistons/seals/fluid, and probably the master cylinder seals too
June 23, 201411 yr Author Not sure what you mean by "middle seals" Some calipers are made of 2 halves, bolted and dowelled together, mostly they come with advise never to seperate Unless there is evidence of leakage there, I think Id be inclined to just replace the pistons/seals/fluid, and probably the master cylinder seals too the rear caliper had bad white rust on.so ive cleane them up.just need to respray them and new seals and pistons and their done .so i need the middle seals
June 23, 201411 yr Moderator What year is the bike (one of the benefits of adding a little detail to your profile)? Have a look here and see if you can see the part - you may need to change the year etc. LINKY
June 23, 201411 yr Author What year is the bike (one of the benefits of adding a little detail to your profile)? Have a look here and see if you can see the part - you may need to change the year etc. LINKY its a 1997 .thanks for the link that's very useful
