Posted April 4, 201411 yr Hey All, I have a problem with my electrics / battery. Every time I do anything near the rear lights my battery drains flat. This time I was fitting a nice little rack to the back (fits to the same bolts as the lights). Rack fitted and went to start and it was dead. It's a new Varta Gel battery and was pretty much charged (a couple of weeks back). Sods law, I went to re-charge it and my charger was nacked so ordered up a new Oxford optimiser. This has happened a few times. Any ideas? Cheers.
April 4, 201411 yr Moderator What charger were you using? You can kill gel batteries if you don't use a correct one? I would also look for anything earthing out and draining the battery; a faulty switch or a wire touching earth.
April 4, 201411 yr Author It's a 12v trickle charger. Ordered up a new Oxford 900 now. I'll check for any faults. Thanks for the advice. As it happens I just got a call off a mechanic asking for a van livery. Will be offering a wee livery for a repair or two. Save me a few quid hopfully.
April 4, 201411 yr The brake light is the only thing fed all the time so I would check the brake light wiring must be rubed through some where.
April 4, 201411 yr Yeah have to agree must be a dead short somewhere unless you have cooked the new battery with a car charger.
April 9, 201411 yr Author Hey Guys, The new charger showed no faults in the battery. Doing a wee contra with a mechanic and he's away with the bike and will check that when sorting a few other wee things. Be back on 2 wheel shortly my fat lazy ass does not like this walking nonsense. Thanks for the advice.
