March 26, 201411 yr Hi guys... I have a Virago 535....Starts really well when she's cold ( almost immediately)...but if I try and start it when she's hot....she'll turn over and not fire...wearing the battery down! If I have waited a few mins tp cool a bit it seems OK again... I am a bit concerned, in case I stall it at lights or summat !!! Any ideas? Cheers
March 27, 201411 yr Author Defo not the choke...that seems fine.... will have to get carbs etc checked out! thanks!!
March 27, 201411 yr I had a similar issue with an old xs1100. Turns out there was a crack in one of the coils which would open when hot.
March 27, 201411 yr Other simple thing to check is the gas cap vent.pop the cap open and see if it starts. What I would do is to get the bike hot and not starting and quickly cool the different parts of the electrical system 1 at a time,coil cdi,pick up coil,a can of compress air will work for that. And repeat if 1 part is suspected to be failing when hot.This could be the start of a elec part failing.
