February 11, 201412 yr Hello guys, recently a friend gifted me a helmet that he used to ride a few years ago, other than the fact that I don't how good the brand is (JHL) and some dirt inside, it's fairly fine. But I was thinking about repainting it the same colour it already is. Is it possible with just some sand paper and a can of primer and spray paint? Or is it not as simple? Thanks in advance Sent from my iPhone using Tapatalk
February 11, 201412 yr I would advise not. Paints etc may react with the material the helmet is made from. Has it ever been dropped?
February 11, 201412 yr Author I would advise not. Paints etc may react with the material the helmet is made from. Has it ever been dropped? I guess so since its got some scratches on the rear of the helmet.
February 11, 201412 yr Moderator Never buy or use a second hand helmet. Never paint a helmet (although some can be painted). Change your helmet every few years.
February 11, 201412 yr when i was learning to ride my instructor told me that they should be changed every two years, or as soon as it is dropped. It's is highly advised that you get a new one. But of course it is totally up to you.
February 12, 201412 yr If you use a second hand helmet you're risking your head. You don't know how the previous owner (mis)used it. As for repainting, absolutely not.
February 12, 201412 yr Plastic degrades over time - several aspects. Sunlight, rain, heat, cold. Acrylic has 'memory' which means every time it flexes it tries to return to its original shape. Just look at an old bath panel or washing machine and you will probably see hairline cracks at the corners. If it has been dropped, the polystyrene could easily have been compressed already and offer no protection for your skull. In short don't use it for anything more than fancy dress!
February 16, 201412 yr Author Thanks for the advice guys, didn't know much a helmets. Much appreciated! Sent from my iPhone using Tapatalk
