This post is 3955 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
I have a problem with a Thunderace swinging arm fitted to a FJ, basically I need to know the distance
between the ends of the swinging arm of a standard Thunderace, either the inside measurement or outer of the solid blocks at the end of the swinging arm. Thanks in advance.
Moved to workshop.
Wot no intro " :eusa_naughty:
