tzr125
jonnytzrroberts
This post is 3942 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Can you stop posting the same thing all over the forum! Say a proper hello in the new members section.
Use bigger jets in the carb to compensate for the extra air.
No worries and I am sure people on the forum can help. Pop over to the new members section and start a thread saying a little about you - read some of the previous posts if it helps.
If you have an aftermarket filter that allows more air to flow you need to increase the jet sizes. Normally the main jet, the pilot jet and you may have to raise the needle by one click. A lean running 2 stroke will put a hole in the piston and cause all sorts of trouble and expense.
