Got to agree.
charge the battery. Check all the bulbs are 12v and 21 w
  • Replies 74
  • Views 22.4k
  • New Indicator bulbs all around and it works perfectly . Thanks everyone. You have all been amazing
  • I love this forum
  • Good Morning everyone. So first thing I checked was float height which was around 6mm lower than it should have been, so I adjusted that. Put it all back together and it literally started straight aw
you mean the right wont flash ;)
could be a bad connection of a dirty contact in the switch...or
Oops, yes I do haha. I will check everything mentioned tomorrow.
thanks
Kim
positive, I could see through it and all the holes were clear on the side.
The pilot jet doesn't have holes in the side. The pilot jet is a small single flatbladed screwdriver removable item about the size of a small pea with one tiny hole through its centre.
I think your thinking of the main jet.
No, I mistakenly thought you were refering to the needle jet holder/emulsification tube. Forgot that pilot jet had some as well :eusa_doh:
I'll go back to sleep... best of luck.
Kim after you are sure that you have all the right bulbs and good grounds /clean sockets,if it still wont flash try flicking the flasher relay with your finger if it flashes then the relay is sticking,sometimes you can file the contacts clean though normaly its best to just replace.
New Indicator bulbs all around and it works perfectly :D. Thanks everyone. You have all been amazing
:thumb: We are waiting for the next question now :lol:
It won't be long haha. Thank you though :)
Cool another success story for the YOC any picts of the bike??
.Your not all wrong YB,, the dt / Yb pilot only has 1 hole straight thru,, :thumb: They all differ
Glad shes all sorted kim... :rolleyes:
Thanks for your help. I will try get a photo when I bring it home, It passed it's mot though, had a couple minors but no Issue so that's great too :)
Kim
