I recently purchased a new float vavlve from yambits as the DT was leaking fuel when standing and running rich. Problem is it doesnt look anyhing like the original. The original is a screw fit and this is non threaded and has a rubber seal . Does it just push in ???? If not where on earth do I get a replacement from >????
Does your dt have the mikuni flat side carb on still if so I have 3 of these carbs and none of them have a threded float valve :s
What year is the bike? as it looks like the early ones with the round carb top did have a screw in float valve seat and the later flat slide carbs were held in with a screw and retaining plate.
Another workshop question in the bar. Topic locked.
This topic is now closed to further replies.
