Crankcase sealant
Hi, when you put crankcase halves together, in my case a 250LC, what sealant do you use. I've seen Yamabond 4 mentioned but it seems hard to get in this country (google search).
Cheers
I used an oldie called wellseal, they used them on the brit iron.
you apply with a fine brush either side and let dry, no squelching out between cases as the other sealants do
I used blue Hylomar, whatever u use , go sparingly, :yeah:
I used Yambits sealant last time and it works fine no leaks and its Silver in colour which is a bonus.
I'm with Blackhat on this. Comes in red also.
Thanks for pointing me in the right direction, can't beat the experience of others
