Clutch
giblet
This post is 4012 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
My 750 Genisis stalls when I put it in gear, done all the seals, got pressure etc? Could too much oil bind the clutch, could old plates grip when new ones wont? It was working fine bar slight air leek requiring bleeding. Any Ideas most welcome I miss not using her.
Link to comment
Share on other sites
Not the best INTRO I have ever seen but better than nothing I suppose !!!!! Welcome to the YOC :jossun:
Link to comment
Hi giblet" :wavey: got all the symptoms of plates stuck together, :eusa_think: rock it in gear ,while pulling lever,,,, if that dont work ,its a strip job, as summat not correctly installed,,, i always pull clutch to see them work ,before i put back on engine cover,,
Link to comment
This topic is now closed to further replies.
  • Recently Browsing
