November 22, 201312 yr Old story I suppose, I had a 1975 Yamaha Enduro (DT) 125 when I was a teenager. Loved that bike. I've been keeping my eyes open for another - not a museum queen, rather a nice solid example that I plan to plate and ride. 125, 175, 250, either would suit my purpose, but what I'm hoping to learn is some of the pitfalls to watch out for. Even back when I owned one as a kid, I was never very knowledgeable on these things. My dad kept an eye on us and the bike was very reliable. Aside from the obvious, I'm looking for some key points to consider when shopping around. Any advice would be much appreciated. Thanks in advance! Jeff (newb)
November 22, 201312 yr Moderator Best bet is a DT175. Great mix of parts availability and keeping up with traffic. The 250 and 400 are harder to find parts for and the 250 is no faster. Look for one that has not been messed with or customised parts fitted.
November 23, 201312 yr As he says" go for the bigger cc"s . as you"l have gained weight since 1975 . . The 125 is rather slow compared with modern 125"s Heres mine
November 24, 201312 yr Author NICE! Thanks for the replies fellas. I found a 250 that I'm strongly considering. I'll post if I pull the trigger... Jeff
November 26, 201312 yr Author BOUGHT IT! Man the smell and sound takes me back. I'll try and get a few photos up as soon as the weather improves and I can get it cleaned up a bit to snap a couple. It seems to be in really good shape, but the turn signals are gone. As soon as I can score a set, I'm planning on plating it and cruising around our small town. I hope there aren't any issues that aren't readily apparent. A friend of mine here used to run a Hodaka dealership back in the 70's and he's very familiar with old 2-strokes. I'm going to let him give it a good once-over and see what it needs. Jeff
November 26, 201312 yr How old put" is it A DT1 ..[69] or a dt2 / crank seals will be only issues. this will show after shes hot,,, if idle creeps high.
November 27, 201312 yr Author blackhat250 thanks for the tip. I'll keep an eye out for that. It's a 1975 DT250B. Not sure of the exact date of manufacture. Jeff
December 7, 201312 yr Author While waiting for more paperwork to get it plated, I've been poking around a bit. Something popped up that scares me - the oil filter support screen looks to be wrapped with a section of white athletic tube sock! It's oiled, mind you, and well greased on the ends to seal, but still LOL. Opinions on the K&N replacement filter YA-4074? http://www.knfilters.com/search/product.aspx?prod=YA-4074 I could get a bag of socks for cheap LOL Thanks, Jeff
December 7, 201312 yr Yeh jeff " i have K&N om my H2 .. and runs good, shouldn"t need jetting,,,,.what about some pics,,,
December 9, 201312 yr Author Couple pics, hope it works. First time using tapatalk on my phone.. Sent from my iPhone using Tapatalk
December 9, 201312 yr Lovely jeff " i now have a hankering for the DT250 again,,, they were yellow in europe .. i had a Dt 400 in 2010
December 10, 201312 yr Author That's a sweet looking 400. I'd love to add one of those to the stable. Jeff
December 10, 201312 yr Believe it or not" there is little difference in performance , between the two fifty and four hundred. 400 tops 80mph 250- 75mph. A bit more torque maybe,,
December 11, 201312 yr Moderator Believe it or not" there is little difference in performance , between the two fifty and four hundred. 400 tops 80mph 250- 75mph. A bit more torque maybe,, True but when the 400 is slowly pulling away you wish you had the extra cubes. The twin shock models are so much prettier in the 250 and 400 range. There is a white 400 on uk fleabay at the moment I keep looking at but it is the monoshock. I am very tempted though!
December 11, 201312 yr I think you"d be quite dissapointed Newman" i had the mono DT400 in 1980, i was beaten by an XT250, ,,for top speed, i did hav a pillion on ,, but we were both 11 stone,,,,
December 11, 201312 yr Moderator Cheers for the info John, I am never going to be 11 stone again The TS250 tops 70 so back to the drawing board. Maybe a TDR or get my RD400 on the road!
December 17, 201311 yr Author This is the tube sock job LOL It has a K&N there now and runs just fine. Sent from my iPhone using Tapatalk
December 17, 201311 yr Moderator Half a sock! This would make jetting a nightmare. With a huge main jet it would probably be really rapid until it blew the piston.
December 17, 201311 yr How much did you have to pay the security guard to turn his back while you snuck it out the back door of the museum,thats one clean bike you found.Looks prety much original,doubt it seen much if any dirt,how many miles on her? I dont think NOS signals are going to be easy to find but aftermarket copys should be easy,emgo used to make em,a couple of fork seals and seat cover and she's a driver. Speaking of seats hows the base? They can get bad quick once the seat cover rips and water gets traped in there
