I'm facing a slight seat dilemma, the more I stare at the sr seat the more I want to burn it, just so horrible like who would design such a thing?! Basically I'm looking for a seat a bit like
Posted Image
Thin and just like this, simple plain black, cheap too hopefully, can anyone direct me in the right place?
Don't know how long I can last with the current seat ugh!! I've already had a brief look and can't seem to find much!
Try making your own. Go to a breakers yard pick up some seat leather and some foam, then shape a bit of aluminium or mild steel and away you go
Would probably turn out horrendous but I guess it might be worth a go
Im supprised foamy aint made a comment on how you could put a photo of his face on your seat too :eusa_whistle:
Or even use the existing seat base - Just add some better foam and re-cover it.
There are professional places that re-upholster seats to your requirements. There used to be one round here somewhere... I'll check around.
you would need to shape the rear frame for a seat like that.
You will have to relocated all the electrics, smaller battery and then make a hoop for the rear and get it welded on.
can't do one thing without changing something else I'm afraid.
that actual seat bit is the easiest :)
These three places are local to you:
http://www.saddlecraft.com/
http://www.dandgupholstery.co.uk/motorbike.php
D P Leathers
243a Westgate Road
Newcastle Upon Tyne
Tyne & Wear
NE4 6AE
Tel: 0191 232 4450
Email: [email protected]
Motorcycle seat specialist. Recovered, rebuild and resculpt. Motorcycle leather repairs and alterations. Open 10.30 - 5.30 Monday to Saturday.
