Hi new to the forum just bought a yamaha dtr125 2003.over last couple of days have made a new cover for rh side powervalve, new battery, soldered wore backnon temp sender, replaced clock bulbs, stripped and cleaned rear caliper as was binding occasionally and a new clutch cable and mixture screw (on order from yamaha).bike is now roadworthy but have a problem with the rev gauge and temp gauge lights speedo side works fine.turning the lights on and only speedo side iluminates and when switched to high beam the rev gauge lights up.neutral light doesnt come on either and the indicators flash rapidly.anyone got any suggestions removed fairing and headlight other day (aftermarket not origional) and there is a blue and red wire which has come unplugged but cant find what it plugs into.
Just to add I didnt fit the aftermarket front fairing and headlight think its polisport amd will be fitting standard one as wires are on display
Someone has messed the wiring up. Maybe in converting the headlight. The flashers could be fed from the wrong coil and taking too many volts
Have fixed for the moment by cutting the rev gauge bulb out of the loom and connecting to power feed of sidw light bit of a bodge but got other things to do on thw list at the mo.will properly fix it when I get a chance also neutral light isnt working tested bulb holder and no power going to it any suggestions would be appreciated
What do u mean by wrong coil sorry not very good qith electrics qas hoping for something simple like flasher relay
