no stranger to bikes but as far as 2 strokes go my knowledge is zero
just brought a dt175mx basket case so i can escape this winter from mrs miffa and her silly soaps ....what may seen stupid questions to you all stars are deadly serious to me ...
so heres the first few of many dumb questions to come
there's no 2 stroke oil tank/container fitted ,don't even know where on the bike it should be and what the tank connects to, theres a blanked off inlet on the carb??? what draws the oil ???? surely some kind of pump?????so when you amazing people tell me how to locate the pump ,how do i test it?????? as me thinks if its been removed does the pump work??????
many thanks in advance miffa
The oil tank is under the seat. A clear plastic tank. an oil pipe should run from here, behind the engine to the front right of the crank case. If you remove the right hand front cover on the crankcase, the oil pump should be visible there. The black pipe from the tank will go into the pump and there will be a pipe from the pump to the carb. There will also be a cable which is connected to the throttle to the cab by the means of a cable splitter.
There is a way to test the pump but the first thing is to see if you have one. The pump is better than premixing fuel as it changes the oil flow automatically depending on the bike revs. If you premix, the oil ratio remains the same and this can mean the bike runs too rich or lean.
cheers Mr dirty
probably wrong tho but don't think the tank would have been located under the seat,the seat is bolted down not on a latch, when i looked under it the space seems to be taken up by the air box ,agree with the constant changing of the amount of oil supply via a pump, much better with one as it will be a pain to pre-mix all the time
i will remove the casing tomorrow to see if ones fitted .....if there is one is there a test i can do to see if its working
thanks miffa
Viewed when the seat is taken off. Pull off the side covers and it will be on one side depending on what year the bike is. They moved the location when they changed the exhaust shape and the swing are from round to square.
thanks again guys for your time
airhead
in 1981 the oil tank was behind the RH side panel, it should still be there unless someone removed it ;)
yes see where it was meant to be but its long gone
oil pump gone as well but the shaft worm is still in place
now then my new made friends does any one have a spare under there work bench for sale along with tank and other bits to make it work ,i will repeat this plea in the wanted section
dumb question number 2
this misfit of a bike must have been put together by stevie wonder and helped by ray charles i think theres half of it missing
right mixed some oil and petrol to try and start and to my amazement after 5-6 kicks brum brum but noticed the amount of exhaust smoke coming from the cylinder head checked and tightened the exhaust manifold that was very loose, haven't removed it completely as yet so unsure if there has been a gasket fitted so the question is would these little engines run if there were no head and base gasket fitted???? can anyone give me the torque setting for the top end as i will be whiping the head and barrel off later this week to see whats missing out of there
Barrel 28.93 lb ft Head 18.8 lb ft Is what I have.
I would guess the gaskets are shot or cheap patten ones rather than missing. Best to buy OEM or Athena gaskets when replacing as patten ones are really bad.
You need to be a paid member to put an ad in the wanted section. I guess that it would be worth the money to do this as it is surprising what spares DT175 members on the forum have. See my signature for a link if you are interested in being a paid member.
cheers for that
took the top end off today,its about time i said something good about this crock of shit well there was no exhaust gasket fitted barrel nuts were finger tight ,but the good news is piston ,rings,gaskets and bore all in tip top condition
cant get my head around just how basic these 2smokers are they really are child's stuff in comparison with the old shit im used to
dumb question number 3
oil pumps are they interchangeable with other yam models say a early dt or a mx125cc are they the same part number?? so i can broaden my search
​still have not found a manual and more importantly a parts catalogue on line as yet
thanks once again miffa
question to mr airhead
am i right in thinking the blue dt at the start page is yours if so nice bike, and where did you get the tank cover as you might have guessed my tank is racked off as well
cheers miffa
Parts information here LINKY
Best place for a manual is fleabay - No links to manuals are allowed on the site as they are copyright protected.
cheers miffa
Hi miffa, yes thats my bike mate, I got the tank cover many moons ago from ebay but I havent seen another like it since...However I did see a black one go in the last week or so, you should have been onto that?
I dont know about the interchangeability of pumps from other bikes, you'll get one eventually without a doubt, even if it comes from the states (DT175E, DT175F) I know from what I've seen posted in the past that there are pit-falls fitting pumps from other bikes, namely that the teeth pitch on the gearwheel in the pump may not match the worm that is driving in ...resulting in stripped gear...bear this in mind.
Parts manuals come up on ebay readily enough, as do workshop manuals. Meantime if you need any help or part numbers just ask
cheers mr airhead
ok its that time of day again .....its dumb question time......
motor back together its now running i suppose as it should and sounds like a cat being attacked by mouse :eusa_whistle: ,no more leaks from the exhaust or topend
sorted the mess the wiring was in, put a new battery on and its charging i think .....whats the charge rate these pea shooters give out with lights off and then on please
going to spoil you lot tonight heres the second dumb question
stripped the carb down to clean it as thought there was some grit under the float needle as the carb was dripping with the fuel left on, it was dirtier than a roman catholic priest, but after putting it back on same problem so how tolerant are these on adjustment raising the float??
strip forks and replace seals tomorrow
many thanks miffa
cheers mr airhead
many thanks miffa
Charging, the manual says...
Lights off...
at 3000rpm 1.3 + - 0.5 amps
at 8000 rpm 1.6 + - 0.5 amps
Lights on
at 3000 rpm 0.4 + - 0.3 amps
at 8000 rpm 1.8 + - 0.5 amps
Charge coil resistance 0.30 Ohm + - 10%
Carbs overflowing is quite a common problem, it may be a worn float needle, examine it for a wear ring around the taper of the valve, float height is 21mm from the gasket flange (below the gasket)
well gone about as far as i am going with this wonderful piece of jap history
another brit bike came into the fold yesterday so space is a premium , the yamaha has to go ,got the fork seals late yesterday so not fitted but supplied think thats all it needs now for the mot and running in properly ,it will end up on ebay unless its sold else where
if any one wants a pic or two PM me your email
thanks guys for all your help, great forum you lot have got
if theres any help i can return regarding british stuff just shout
cheers miffa
oh sorted the carb
  • 3 weeks later...
you will all be pleased im back again :spin2:
bike never took a bid on ebay ,so they aint the sort after classic i thought they were :eusa_think: but had loads of emails after the item ending asking how much would take ,gave them all the same answer bollocks you should have bid
anyways did the fork seals and it passed its MOT and even tho these bikes are the biggest piece of shite ive ever rode theres just something about them, so decided to keep it and blow it up
took it green laneing this morning what a laugh, :hah: it through me off twice but it put a smile on me face,got some pics but cant work out how to upload them and theres todays dumb question ?????
cheers miffa
Hmmm deliberately trying to kill a Dt.
Unless you do something daft like pinning the throttle and waiting for the bang, if its healthy you wont kill it.
indestructible you say.........we will see..............engine very healthy but it certainly aint no trailer queen ,should imagine the larger cc models must be fun,find them a bit boring on road but not to bad chasing rabbits
cheers miffa
Why did the britts have a 360degree crank on twins and not 180 ? shurly this would be smoother,,,
Bit of a what came first chicken or egg question
Be good to hear your take on that
Why did Edward turner decided on 360 oppose to 180 back in 1928 well the answer to that was never recorded?
I know that turner was inspired by the two central cylinders on his riley car engine and that drove him to design the early known Ariel square four engine that should have been the BSA square four but was rejected by BSA in the same year ,he then went on to remove two pistons and conrods to see what it would run like as a twin
In 1936 sangster who owned Ariel then brought triumph and made Turner general manager
But in answer to your question Mr. blackhat both 180 and 360 both have their draw backs but they said that the 360 degree made around town riding more buzzy as well as being easier to set up using a single carb and a simple ignition system with one set of points and a distributor.
Whatever it was, he knew that vibration would be a problem and he specified things that remain radical to this day, like the forged alloy conrods to minimise reciprocating weight.
But IMO ....come on there aint nothing on this planet that sounds like a Brit 360 degree twin is there.
Cheers miffa
