Posted September 22, 201312 yr hi guys does any one no if you get ( jacks o2 mod ) for the xvs 1300 in the uk or is it just ,usa.
September 22, 201312 yr Moderator just bi this 1 http://www.ebay.co.uk/itm/260961310339?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D260961310339%26_rdc%3D1
October 3, 201312 yr Get the o2 eliminator from the guy in greece off ebay, cost £17 and a few pence, does the same job as jacks mod, i fitted one on my 1300 and it's the best thing i ever did, much smoother at low revs and doesn't affect mpg or running, only takes 5 mins to fit
October 3, 201312 yr Author cheers guys a got the one of the link drewpy had on, a think its the one you said eggar from ebay well thats it on know just to take it for a run.
October 10, 201311 yr Author yep, what a difference a thought at first it was crap, but once a got out on the road and going up and down the gears, best £17 a have spent cheers guys.
October 11, 201311 yr Author ...and the consumption? a don't no yet no been for a big run I will let you know, cheers
October 17, 201311 yr Made no difference to my MPGs when I used one. If you are handy with a soldering iron, Jack posted full instructions here http://vstar1300.pbworks.com/w/page/5760698/Jack's%20O2%20Mod
October 29, 201311 yr I fit today this eliminator on my bike, I don`t feel any difference of power BUT now I can easy run my bike in 5th gear at 40 m/h and this is a big improve. before eliminator I can`t run in 5th gear with a minimum of 50m/h. so, I can say is a win
March 21, 201411 yr 1 month ago my o2 sensor eliminator die and I put back the 02 sensor. ok, no big deal.. under 20 pounds, was working 3 months.. anyway not this is why I bump this topic. when i ask if the consumption is modified, people say they don`t see any change.. but is... I saw that from start but I say maybe is because of the weather, because is cold... but nope, after I put back the 02 sensor, the consumption was reduced.. and the weather was still bad, still cold... normally I do combinated, town-outside something like 135-145 miles before the led is coming on. with the o2 eliminator, I do maximum 125 miles before the led is coming on. now i`m back to 140-145 miles. so, the consumption is over 10% increased with the sensor eliminator. I think the power gain is not worth so I will stay with the o2 sensor on
June 25, 20169 yr With the O2 eliminator pictured do you just plug it in where the O2 sensor plugged in and leave the O2 sensor disconnected. TY in Adv
