Posted September 19, 201311 yr Hi, I just bought some Chinese heated grips and I need some help to fit them. First, how could I remove the old grips? Second, where it would be ideal to connect the power wire? Cheers,
September 19, 201311 yr Hi bud. removing old grips is a stanley knife jobby unless they are loose enough for you to peel them off, as for where to put them, you could wire in a relay with a split feed from something that is only on with the ignition, maybe the headlight or something.
