Hi,
I just bought some Chinese heated grips and I need some help to fit them.
First, how could I remove the old grips?
Second, where it would be ideal to connect the power wire?
Cheers,
Hi bud.
removing old grips is a stanley knife jobby unless they are loose enough for you to peel them off,
as for where to put them, you could wire in a relay with a split feed from something that is only on with the ignition, maybe the headlight or something.
Thank you!
I didn't know that I need a relay, so I order it just now.
Don't post workshop questions in the bar please!
This topic is now closed to further replies.
