September 16, 201312 yr Author how can i make my rd smoke like fuck , as it hardly smokes at the moment without torching it. would doubling my oil up do the trick or would i fuck something up.. i only want to see it smoke , i wouldn't do it regular..
September 18, 201312 yr Moderator I would not recommend any of these but............... Part fill it with diesel. Part fill it with redex. Stick a roman candle up the exhaust and light it. Run it with a 50/50 mix of 2 stroke. Mix some 4 stroke oil in the fuel. Johns TS was smoking at Squires, just enough though so try the oil he is using.
September 18, 201312 yr Yeh kev " these fully synthetic oils are low smoke, the old mineral oil [ Shell sx] or the like , reek like fook. Carlube is semi. and smells like old school oil... ... as Dirty says diesel in the petrol is like fog,,,, stinks too..
September 18, 201312 yr Author do you put diesel instead of two stroke oil , or as well as ? and will it do any harm.
September 18, 201312 yr wuddna recommend Diesel... it will run with a small amount. i had 7 ltres to 7 ltres of petrol . It ran. but smoke screened the A1. when i dumped the fuel[ layby.] it struggled to start. even with fresh petrol , took plugs out, fouled badly...
September 18, 201312 yr or you could use your old chip pan oil instead of derv should smell nice too MMMM Chips
September 20, 201312 yr Author i just read about this stuff . anyone tried it.. http://www.ebay.co.uk/itm/like/171060662522?showlimghlp=true&lpid=92&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=92&ff19=0
September 29, 201312 yr Author I just got back from sladeburn with my chums. Using this exol oil for the first time. Fucin shite No smoke at all . None. Low oder. But it seems quiter and smoother on exeleration. So I will try it again at this price..
