Is there a warning when the oil pump fails?
Hi all!
Are there warning signs when the oil pump fails on my bike, and if so, what are they?
Thanks in anticipation
I.L.
Ultimately the biggest warning you'll get is engine seizure...yikes
Best to fit a clear tube between the pump output and the carb and any air bubbles present in this tube should be investigated
Also the seals can dislodge or start to leak...If the pump drive seal leaks badly your gearbox oil level will be increased by the leaking 2T oil
The pump piston also has a small seal and if that one is leaking you will see 2T oil in the pump compartment
The pump should be bled though do you know the bleeding procedure?
Personnally I'm a big fan of these pumps myself...far better than premix IMO
so why do you thing your pump is failing?
You will feel the engine starting to nip up a little as well.
As airhead says, keep an eye on the oil line into the pump ensuring no gaps or bubbles
kinda looks like te tach and the pump are drive from a common point... if your tach fails shut it down would be another recommondation
