Posted July 17, 201312 yr Hey, I wonder if can help? I went for a ride the other day and as I reached around 60 mph my bike seemed to drop power for a split second and then a warning light come on! It stayed on till I stopped, turned engine off then it flashed 4 times then off then 4 flashes again. It almost seems that a high rev makes the light turn on. I changed spark plugs, air fIlter and changed oil and filter to boot! Still seems to happen? Any ideas out there?
July 18, 201312 yr You're supposed to take it to a dealer and pay 1 hour of labour for the minute it takes to decode this. However... "Apparently", there are only two fault codes listed for the XVS 3 blinks for the TPS and 4 blinks for the speed sensor. Since I don't know of any speed sensor on this bike and because the symptoms sound like it - I'd expect the issue to be the Throttle Position Sensor, or more likely one of the wires from the TPS in need of checking. There's a few YouTubes that show how to test the TPS. In case you don't know, it's Part 45 in the Carb schematic here: http://www.cmsnl.com/yamaha-xvs650apapc-2002_model11085/partslist/B-02.html#results
July 18, 201311 yr Author Thanks very much man, I did go to a dealer and the guy advised me to go somewhere else as it was £80!! I will have a look into these and hopefully will have it running nice again!!
July 18, 201311 yr Did you test the TPS and the wiring around it first? Did the dealer also check the flash code, or was that what the £80 was for? If you need a new one, check eBay. Like this: http://www.ebay.co.uk/itm/00-2000-YAMAHA-XVS650-XVS-650-V-STAR-THROTTLE-SENSOR-36-/330940168216?pt=Motorcycles_Parts_Accessories&hash=item4d0d923818 Chances are Yammie used the same one on other bikes. The V-Max uses some of the same components as the Drags, for example. Part numbers may help, too.
July 18, 201311 yr Author I haven't checked the TPS yet, will look over the weekend. The £80 charge was just to see what was up with the bike, he said go somewhere cheaper. This was only a few days ago. I'll post up how it went and see If it solves the problem!
July 18, 201311 yr i've never done this so have no idea if it works but if you remove the battery for an hour this will "reset" the system when you refit the battery evrything will be back to normal as said i've never done this but have heard it works suppose theres nothing to lose
July 20, 201311 yr Author So I unplugged the battery for around 40 mins yesterday just to see and rode to work today, I must say it seems to have improved! No light came on and it didn't seem to struggle, quite amazing how much power was lost. She seems a lot happier now. Thanks for you help guys!
July 21, 201311 yr fingers crossed the problem doesnt come back! Nothing worse than intermittent faults. Youll be watching out for it for ages long after its fixed
July 22, 201311 yr Moderator now go and buy an XS650 without all the electric crap , preferably with a Halco 860 conversion :hah: :biglaugha: :biglaugha:
March 18, 201510 yr Hey, sorry to bring this thread up again , but did this issue ever happen for you again ? Same thing is happening to me since the speedo cable broke and its been replaced I tried disconnecting the loom from the battery overnight, it didnt help :/
